ONTAP EMS reference
mcc.kill events
mcc.kill EMS events occur when the node is halting because it received a "kill" message from the disaster recovery (DR) partner.
mcc.kill.received
Severity
INFORMATIONAL
This message occurs when the node is halting because it received a "kill" message from the disaster recovery (DR) partner.
Corrective Action
(None).
Syslog Message
Node is halting because a kill message with reason %s has been received from the DR partner with system ID %ld.
reason (STRING): Reason for halting the node.
sender_sysid (LONGINT): System ID of the sender.
