fci.flash events
fci.flash EMS events occur when ONTAP encounters issues associated with Fibre Channel adapter flash preload table updates.
fci.flash.preload.failed
- Severity
ERROR
- Description
This message occurs when there is a failure updating the Fibre Channel adapter flash preload table. If the preload table cannot be updated, the adapter might not have the best configuration settings for the PCI Express link.
- Corrective Action
In most cases the adapter will still function normally. However, if you see PCI Express correctable errors on this adapter, you should replace the adapter.
- Syslog Message
Failed to update flash preload table on Fibre Channel adapter %s with error %d.
- Parameters
port (STRING): Name of the adapter port.
errorCode (INT): Update error code.
fci.flash.preload.reboot
- Severity
INFORMATIONAL
- Description
This message occurs when the Fibre Channel adapter flash preload table has been updated and the controller is rebooting for the new settings to take effect.
- Corrective Action
(None).
- Syslog Message
Rebooting for updated Fibre Channel flash preload table to take effect.
- Parameters
(None).
fci.flash.preload.updated
- Severity
INFORMATIONAL
- Description
This message occurs when the Fibre Channel adapter flash preload table is updated. The preload table contains configuration settings for the adapter.
- Corrective Action
(None).
- Syslog Message
Updated flash preload table on Fibre Channel adapter %s to version %s.
- Parameters
version (STRING): Preload table version.
