ONTAP EMS reference
fci.flash events
fci.flash EMS events occur when ONTAP encounters issues associated with Fibre Channel adapter flash preload table updates.
fci.flash.preload.failed
Severity
ERROR
This message occurs when there is a failure updating the Fibre Channel adapter flash preload table. If the preload table cannot be updated, the adapter might not have the best configuration settings for the PCI Express link.
Corrective Action
In most cases the adapter will still function normally. However, if you see PCI Express correctable errors on this adapter, you should replace the adapter.
Syslog Message
Failed to update flash preload table on Fibre Channel adapter %s with error %d.
port (STRING): Name of the adapter port.
errorCode (INT): Update error code.
fci.flash.preload.reboot
Severity
INFORMATIONAL
This message occurs when the Fibre Channel adapter flash preload table has been updated and the controller is rebooting for the new settings to take effect.
Corrective Action
(None).
Syslog Message
Rebooting for updated Fibre Channel flash preload table to take effect.
(None).
fci.flash.preload.updated
Severity
INFORMATIONAL
This message occurs when the Fibre Channel adapter flash preload table is updated. The preload table contains configuration settings for the adapter.
Corrective Action
(None).
Syslog Message
Updated flash preload table on Fibre Channel adapter %s to version %s.
version (STRING): Preload table version.
