The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mgmt.nfsserver events
Creating your file...
Your file is ready
mgmt.nfsserver.failure
- Severity
ERROR
- Description
This message occurs when a NFS server fails to be configured and, therefore, NFS access might not be available.
- Corrective Action
Check the reason for the error and take action accordingly. For further assistance, contact techinal support.
- Syslog Message
Failed to configure NFS server. Error: %s.
- Parameters
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
mgmt.nfsserver.success
- Severity
INFORMATIONAL
- Description
This message occurs when a NFS server is successfully configured after a failure.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
vservername (STRING): Name of the nfs server.
