mcc.fabricpool events
mcc.fabricpool EMS events occur when ONTAP encounters issues associated with FabricPool license configuration in MetroCluster(tm) configurations.
mcc.fabricpool.license.absent
- Severity
ERROR
- Description
This message occurs when a FabricPool license exists on only one of the two sites of a MetroCluster(tm) configuration.
- Corrective Action
Install a FabricPool license on the cluster that is missing the license.
- Syslog Message
The FabricPool license is installed on only one site of this MetroCluster configuration. The license is missing on cluster %s (ID: %s).
- Parameters
cluster_name (STRING): Name of the cluster which is missing the license.
cluster_uuid (STRING): UUID of the cluster.
mcc.fabricpool.license.diff
- Severity
ERROR
- Description
This message occurs when the FabricPool license capacity or term limits are different for the two sites of a MetroCluster(tm) configuration.
- Corrective Action
Install a new license on one of the clusters so that the license limits match.
- Syslog Message
The FabricPool license limits are different for the two sites of this MetroCluster configuration. The license limits are %s and %s on site %s and %s and %s on site %s.
- Parameters
local_license_limit (STRING): License capacity limit from the local cluster.
local_term_limit (STRING): License term limit from the local cluster.
local_cluster_name (STRING): Name of the local cluster.
remote_license_limit (STRING): License capacity limit from the remote cluster.
remote_term_limit (STRING): License term limit from the remote cluster.
remote_cluster_name (STRING): Name of the remote cluster.
mcc.fabricpool.mirror.missing
- Severity
ALERT
- Description
This message occurs when a FabricPool in a MetroCluster configuration does not have a mirror object store attached.
- Corrective Action
Use the "storage aggregate object-store mirror" command to add a mirror object store to the FabricPool.
- Syslog Message
FabricPool: "%s" UUID: "%s" in a MetroCluster configuration does not have synchronous data protection enabled because the mirror object store is missing.
- Parameters
aggr (STRING): Name of the FabricPool.
UUID (STRING): UUID of the FabricPool.
