repl.extended events
repl.extended EMS events occur when the replication engine encounters a destination that does not support extended time format.
repl.extended.time.format.unsupported
- Severity
ERROR
- Description
This message occurs when the replication engine encounters a destination that does not support extended time format.
- Corrective Action
Select a destination that supports extended time format.
- Syslog Message
Extended time format not supported on the destination of relationship %s.
- Parameters
transferId (STRING): UUID of the SnapMirror® transfer that has the destination that cannot handle extended time.
