ONTAP EMS reference
repl.extended events
repl.extended EMS events occur when the replication engine encounters a destination that does not support extended time format.
repl.extended.time.format.unsupported
Severity
ERROR
This message occurs when the replication engine encounters a destination that does not support extended time format.
Corrective Action
Select a destination that supports extended time format.
Syslog Message
Extended time format not supported on the destination of relationship %s.
transferId (STRING): UUID of the SnapMirror® transfer that has the destination that cannot handle extended time.
