wafl.dirent events
wafl.dirent.illegal.encoding
- Severity
ERROR
- Description
This message occurs when a user attempts to use a directory entry name that is not supported by the virtual server's language setting.
- Corrective Action
Use directory entry name with encoding that matches the virtual server's language setting.
- Syslog Message
The encoding of directory entry name %s doesn't match the virtual server's language code %s.
- Parameters
filename (STRING): The filename
langcode (STRING): Language code
