wafl.dirent events
wafl.dirent.illegal.encoding
Severity
ERROR
This message occurs when a user attempts to use a directory entry name that is not supported by the virtual server's language setting.
Corrective Action
Use directory entry name with encoding that matches the virtual server's language setting.
Syslog Message
The encoding of directory entry name %s doesn't match the virtual server's language code %s.
filename (STRING): The filename
langcode (STRING): Language code
