The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.sameha events
Creating your file...
Your file is ready
config.sameHA
- Severity
ERROR
- Description
This message occurs when a disk is multipathed to the same host adapter. The second disk interface should be attached to a different host adapter.
- Corrective Action
Move one of the connections attaching the disk shelf to a different host adapter.
- Syslog Message
Disk %s and other disks attached to the same port are dual-attached to the same adapter. For improved availability you should dual-attach them to separate adapters.
- Parameters
disk (STRING): Name of the disk.
