ONTAP EMS reference
config.differentswitchport events
config.differentswitchport EMS events occur when the two ports of the disk are connected to different switch ports.
config.DifferentSwitchPort
Severity
ALERT
This message occurs when the two ports of the disk are connected to different switch ports.
Corrective Action
(None).
Syslog Message
Disks on port %s:%d are also connected to port %s:%d. They need to be connected via the same port on different switches. This is an illegal configuration.
switch1 (STRING): (None).
port1 (INT): (None).
switch2 (STRING): (None).
port2 (INT): (None).
