ONTAP EMS reference
raid.diskadd events
raid.diskadd EMS events occur when ONTAP encounters issues associated with disk addition to aggregates.
raid.diskadd.abort
Severity
ERROR
This message occurs when the system aborts the addition of disks to an aggregate.
Corrective Action
Use the reason provided to determine an action from the following list: - Change in raidgroup size: Retry adding disks to the volume. - One of the target plexes has failed: Delete the failed plex. Use the "storage aggregate plex delete" command. When the failed plex is removed and the aggregate state appears as "unmirrored", retry adding disks to the volume. - For further information or assistance, contact NetApp technical support.
Syslog Message
Addition of disks to %s %s%s aborted %s.
vol_type (STRING): Volume type.
owner (STRING): Owner of the aggregate.
vol (STRING): Name of the aggregate.
reason (STRING): Reason the disk addition was aborted.
raid.diskadd.add.abort
Severity
ERROR
This message occurs when the addition of disks to an aggregate is aborted due to a detected disk failure.
Corrective Action
Retry adding disks to the aggregate. If disk list was specified for addition, replace the failed disk with a good disk in the list.
Syslog Message
Addition of disks to %s %s%s aborted due to failure of %s.
owner (STRING): Owner of the affected aggregate.
disk_info (STRING): Information about the disk object, including disk name, path, shelf, bay, serial number, vendor, model, RPM, and carrier serial number.
shelf (STRING): Identifier of the disk shelf where the disk is located.
bay (STRING): Disk bay within the shelf where the disk is located.
vendor (STRING): Name of the disk drive vendor.
model (STRING): String representing the name of the model of the disk drive.
firmware_revision (STRING): Firmware revision number of the disk.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk drive.
disk_rpm (STRING): Rotational speed of the disk, in RPM.
carrier (STRING): Unique ID of the carrier in which the disk is installed.
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is 'Local'.
raid.diskadd.create.abort
Severity
ERROR
This message occurs when the creation of a an aggregate is aborted due to a detected disk failure.
Corrective Action
Retry the aggregate creation. If disk list was specified for creation, replace the failed disk with a good disk in the list.
Syslog Message
Creation of %s %s%s aborted due to failure of %s.
