The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.atanotsupported events
Creating your file...
Your file is ready
config.ATAnotSupported
- Severity
ERROR
- Description
This message occurs when an ATA disk is found, but the appliance does not support it.
- Corrective Action
Remove the ATA disks or upgrade your appliance to a model that supports ATA disks. Check your support provider's web site or knowledgebase for more information about appliance models that support ATA disks.
- Syslog Message
ATA disks are not supported on this appliance. Disk %s is an ATA disk and should be removed.
- Parameters
disk (STRING): Name of the disk.
