scsiblade.pport events
scsiblade.pport.bsh.cancel.timeout
- Severity
NOTICE
 - Description
PPorts LIF migration started before BSH cancel completed.
 - Corrective Action
No corrective action
 - Syslog Message
PPorts LIF migration started before BSH cancel API completed.
 - Parameters
(None).
scsiblade.pport.fcp.dbo.err
- Severity
ERROR
 - Description
This message occurs during a nondisruptive operation such as takeover or giveback, when the persistent port feature is not functioning due to configuration errors.
 - Corrective Action
Collect the system logs, and then contact NetApp technical support. Support needs to see the system logs to determine the appropriate corrective action.
 - Syslog Message
FCP LIF "%s" persistence in Vserver "%s" could not be enabled. Error %u/%u: %s.
 - Parameters
lif (STRING): Name of the network interface (LIF).
vserver (STRING): Name of the Vserver.
errortype (INT): Error type.
error (INT): Error code.
errorDecString (STRING): Error description string.
scsiblade.pport.fcp.init.err
- Severity
ERROR
 - Description
This message occurs when the persistent port object for a SAN FCP network interface (LIF) fails to be configured during a LIF create operation. LIF persistence will not function during nondisruptive operations like takeover and giveback until the issue is resolved.
 - Corrective Action
 - Syslog Message
FCP LIF "%s" persistence in Vserver "%s" failed to initialize. Error %u/%u: %s.
 - Parameters
lif (STRING): Name of the FCP network interface (LIF).
