ONTAP EMS reference
scsiblade.pport events
scsiblade.pport EMS events occur when ONTAP encounters issues associated with persistent port operations and LIF migration.
scsiblade.pport.bsh.cancel.timeout
Severity
NOTICE
PPorts LIF migration started before BSH cancel completed.
Corrective Action
No corrective action
Syslog Message
PPorts LIF migration started before BSH cancel API completed.
(None).
scsiblade.pport.fcp.dbo.err
Severity
ERROR
This message occurs during a nondisruptive operation such as takeover or giveback, when the persistent port feature is not functioning due to configuration errors.
Corrective Action
Collect the system logs, and then contact NetApp technical support. Support needs to see the system logs to determine the appropriate corrective action.
Syslog Message
FCP LIF "%s" persistence in Vserver "%s" could not be enabled. Error %u/%u: %s.
lif (STRING): Name of the network interface (LIF).
vserver (STRING): Name of the Vserver.
errortype (INT): Error type.
error (INT): Error code.
errorDecString (STRING): Error description string.
scsiblade.pport.fcp.init.err
Severity
ERROR
This message occurs when the persistent port object for a SAN FCP network interface (LIF) fails to be configured during a LIF create operation. LIF persistence will not function during nondisruptive operations like takeover and giveback until the issue is resolved.
Corrective Action
Syslog Message
FCP LIF "%s" persistence in Vserver "%s" failed to initialize. Error %u/%u: %s.
lif (STRING): Name of the FCP network interface (LIF).
