      repository.ctpupdate events
Repository.CTPUpdate.Failed
- Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
 - Severity
ERROR
 - Description
This message occurs when an update to the Create Time Placement (CTP) ruleset fails.
 - Corrective Action
Retry updating the ruleset by using the "vserver data-policy import" command. If the problem persists, contact NetApp technical support.
 - Syslog Message
Create Time Placement (CTP) ruleset update failed on the Infinite Volume. Reason: %s.
 - Parameters
reason (STRING): Reason for the failure.
