The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
repository.ctpupdate events
Creating your file...
Your file is ready
Repository.CTPUpdate.Failed
- Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
- Severity
ERROR
- Description
This message occurs when an update to the Create Time Placement (CTP) ruleset fails.
- Corrective Action
Retry updating the ruleset by using the "vserver data-policy import" command. If the problem persists, contact NetApp technical support.
- Syslog Message
Create Time Placement (CTP) ruleset update failed on the Infinite Volume. Reason: %s.
- Parameters
reason (STRING): Reason for the failure.
