repository.ctpupdate events
Repository.CTPUpdate.Failed
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
ERROR
This message occurs when an update to the Create Time Placement (CTP) ruleset fails.
Corrective Action
Retry updating the ruleset by using the "vserver data-policy import" command. If the problem persists, contact NetApp technical support.
Syslog Message
Create Time Placement (CTP) ruleset update failed on the Infinite Volume. Reason: %s.
reason (STRING): Reason for the failure.
