repository.ctpupdate events
repository.ctpupdate EMS events occur when an update to the Create Time Placement (CTP) ruleset fails.
Repository.CTPUpdate.Failed
- Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
- Severity
ERROR
- Description
This message occurs when an update to the Create Time Placement (CTP) ruleset fails.
- Corrective Action
Retry updating the ruleset by using the "vserver data-policy import" command. If the problem persists, contact NetApp technical support.
- Syslog Message
Create Time Placement (CTP) ruleset update failed on the Infinite Volume. Reason: %s.
- Parameters
reason (STRING): Reason for the failure.
