ONTAP EMS reference
kmip2.ssl events
kmip2.ssl.cannot.connect
Severity
ALERT
This message occurs when a KMIP SSL/TLS connection error is detected in either a Cloud ONTAP system with encrypted aggregates or a NSE system. On a Cloud ONTAP® system, this message indicates one of the following: 1) A request to create an encrypted aggregate will not succeed because the key cannot be sent to the external KMIP server, or 2) The request to retrieve a key from the external KMIP server will fail. In this case, the encrypted aggregate will not be able to be mounted. On a NSE system, this message indicates one of the following: 1) A request to re-key a NSE drive will not succeed because the key cannot be sent to the external KMIP server, or 2) The ability to read/write data to/from a NSE drive might be impacted if power to the drive or to the disk shelf is lost.
Corrective Action
Examine the KMIP certificates and ensure that the certificates have been created properly.
Syslog Message
Unable to make SSL/TLS connection to KMIP server. Error: %s
err (STRING): KMIP error code with details.
