ONTAP EMS reference
rlib.duplicate events
rlib.duplicate EMS events occur when an interconnect link IP address on this node has a conflict with an IP address on another node in the cluster.
rlib.duplicate.ip.detected
Severity
ERROR
This message occurs when an interconnect link IP address on this node has a conflict with an IP address on another node in the cluster.
Corrective Action
Reboot either this node or the other node reported in this event, while making sure that all interconnect links on the two nodes are connected, up, and operational.
Syslog Message
Interconnect link IP address %s on this node (System ID %d) is also in use by another node (System ID %d) in the cluster.
dupIP (STRING): Conflicting IP address.
localSysid (LONGINT): System ID of the local node.
remoteSysid (LONGINT): System ID of the remote node.
