ONTAP EMS reference
telnet.setsockopt events
telnet.setsockopt.failure
Severity
ERROR
This message occurs when setsockopt on telnet socket fails
Corrective Action
Use the error code contained in this message to determine the problem.
Syslog Message
Telnet setsockopt error: option %s, option value %s, error code %d (%s).
socketlevel (STRING): This is the socket option level parameter
socketoption (STRING): This is the socket option value parameter
errorcode (INT): This is the error code returned from setsockopt
reason (STRING): Reason why setsockopt failed on telnet socket.
