The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
raid.flexvol events
Creating your file...
Your file is ready
raid.flexvol.lock.conflict
- Severity
INFORMATIONAL
- Description
This message occurs when a configuration operation on an aggregate (for example, adding disks, relocating aggregate disks, etc.), fails to get exclusive lock access because of one or more indirect conflict volume locks held by child volumes within the aggregate.
- Corrective Action
Retry the failed operation after the current operation has completed.
- Syslog Message
Exclusive access on the aggregate %s by operation %s failed because of an indirect conflict flexvol lock with current operation %s.
- Parameters
aggregate (STRING): Name of the aggregate.
attempted_op_name (STRING): Name of the operation that tried to get exclusive access.
current_op_name (STRING): Name of the operation that is currently holding exclusive access.
