ONTAP EMS reference
siw.mpaverrelaxed events
siw.mpaverrelaxed EMS events occur when there is a mismatch in SW-iWARP versions, but due to negotiation or enhanced connect being enabled.
siw.mpaVerRelaxed
Severity
ERROR
This message occurs when there is a mismatch in SW-iWARP versions, but due to negotiation or enhanced connect being enabled. The SW-iWARP booted up with reduced functionality and performance capabilities.
Corrective Action
Upgrade the ONTAP® release on the local node and the partner node to the same version of SW-iWARP to run with full functionality and performance capabilities.
Syslog Message
SIW Version mismatch between the local node and partner node. Local IRD: %d ORD: %d Partner IRD: %d ORD: %d
localIRD (INT): Local IRD value.
localORD (INT): Local ORD value.
partnerIRD (INT): Partner IRD value.
partnerORD (INT): Partner ORD value.
