The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
siw.mpaverrelaxed events
Creating your file...
Your file is ready
siw.mpaVerRelaxed
- Severity
ERROR
- Description
This message occurs when there is a mismatch in SW-iWARP versions, but due to negotiation or enhanced connect being enabled. The SW-iWARP booted up with reduced functionality and performance capabilities.
- Corrective Action
Upgrade the ONTAP® release on the local node and the partner node to the same version of SW-iWARP to run with full functionality and performance capabilities.
- Syslog Message
SIW Version mismatch between the local node and partner node. Local IRD: %d ORD: %d Partner IRD: %d ORD: %d
- Parameters
localIRD (INT): Local IRD value.
localORD (INT): Local ORD value.
partnerIRD (INT): Partner IRD value.
partnerORD (INT): Partner ORD value.
