ONTAP EMS reference
haosc.invalid events
haosc.invalid EMS events occur when the chassis or controller field-replaceable unit programmable read-only memory (FRU PROM) returns an invalid configuration.
haosc.invalid.config
Severity
EMERGENCY
This message occurs when the chassis or controller field-replaceable unit programmable read-only memory (FRU PROM) returns an invalid configuration.
Corrective Action
Boot into Maintenance mode and run the 'ha-config modify' command to set the controller and chassis configuration to stand-alone or HA, as appropriate. Setting the wrong configuration might lead to data loss. If you need assistance, contact NetApp technical support.
Syslog Message
%s FRU PROM returns an invalid configuration.
fru (STRING): Chassis/controller string.
