haosc.invalid events
Creating your file...
Your file is ready
haosc.invalid.config
- Severity
EMERGENCY
- Description
This message occurs when the chassis or controller field-replaceable unit programmable read-only memory (FRU PROM) returns an invalid configuration.
- Corrective Action
Boot into Maintenance mode and run the 'ha-config modify' command to set the controller and chassis configuration to stand-alone or HA, as appropriate. Setting the wrong configuration might lead to data loss. If you need assistance, contact NetApp technical support.
- Syslog Message
%s FRU PROM returns an invalid configuration.
- Parameters
fru (STRING): Chassis/controller string.
