nblade.vscannoscannerconn events
Creating your file...
Your file is ready
Nblade.vscanNoScannerConn
- Severity
EMERGENCY
- Description
This message occurs when ONTAP® has no vscan connection for servicing virus scan-requests. This might cause data unavailability if the scan-mandatory option is enabled.
- Corrective Action
Ensure that the scanner pool is properly configured and the AV servers are active and connected to ONTAP.
- Syslog Message
Vserver "%s" has no virus scanner connection.
- Parameters
vserverName (STRING): Vserver associated with this operation.
object_type (STRING): Type of the resource object under notification.
object_uuid (STRING): UUID of the resource object.
