nblade.vscannoscannerconn events
Nblade.vscanNoScannerConn
Severity
EMERGENCY
This message occurs when ONTAP® has no vscan connection for servicing virus scan-requests. This might cause data unavailability if the scan-mandatory option is enabled.
Corrective Action
Ensure that the scanner pool is properly configured and the AV servers are active and connected to ONTAP.
Syslog Message
Vserver "%s" has no virus scanner connection.
vserverName (STRING): Vserver associated with this operation.
object_type (STRING): Type of the resource object under notification.
object_uuid (STRING): UUID of the resource object.
