ONTAP EMS reference
dbs.master events
dbs.master.didnt.start.cm
Severity
NOTICE
This message occurs when the node fails to execute cluster master startup. The system attempts to start the cluster master again automatically.
Corrective Action
(None).
Syslog Message
Cluster master startup on service ID %u on node ID %u (UUID: %s) failed. Reason: %s.
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID of the associated node.
reason (STRING): Reason cluster master startup failed.
dbs.master.started.cm
Severity
NOTICE
This message occurs when the node completes cluster master startup successfully.
Corrective Action
(None).
Syslog Message
Cluster master startup on service ID %u on node ID %u (UUID: %s) completed successfully.
nodeUuid (STRING): Node universal unique identifier (UUID) of the associated node.
