dbs.master events
Creating your file...
dbs.master.didnt.start.cm
- Severity
NOTICE
- Description
This message occurs when the node fails to execute cluster master startup. The system attempts to start the cluster master again automatically.
- Corrective Action
(None).
- Syslog Message
Cluster master startup on service ID %u on node ID %u (UUID: %s) failed. Reason: %s.
- Parameters
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID of the associated node.
reason (STRING): Reason cluster master startup failed.
dbs.master.started.cm
- Severity
NOTICE
- Description
This message occurs when the node completes cluster master startup successfully.
- Corrective Action
(None).
- Syslog Message
Cluster master startup on service ID %u on node ID %u (UUID: %s) completed successfully.
- Parameters
nodeUuid (STRING): Node universal unique identifier (UUID) of the associated node.
