ONTAP EMS reference
rlib.mccip events
rlib.mccip EMS events occur when ONTAP encounters issues associated with MetroCluster IP configuration.
rlib.mccip.config.failure
Severity
ERROR
This event is generated if any error occurs while configuring MCC/IP.
Corrective Action
(None).
Syslog Message
Configuration error has occured in "%s", while setting up "%s ",with value: "%s", (error string='%s', error code=%d).
objectOper (STRING): Operation being executed.
objectType (STRING): Type of Object - IP address/ Netmask/ Interface / Bootarg
objectValue (STRING): Value of IP address/ Netmask/ Interface / Bootarg
errorString (STRING): The error string
errNum (INT): The internal error code
rlib.mccip.config.missing
Severity
NOTICE
This event is generated if any of the environment data relating to the configuration of an MCC/IP DR port is missing on boot.
Corrective Action
(None).
Syslog Message
(None).
objectOper (STRING): Interface being configured.
