rlib.mccip events
rlib.mccip EMS events occur when ONTAP encounters issues associated with MetroCluster IP configuration.
rlib.mccip.config.failure
- Severity
ERROR
- Description
This event is generated if any error occurs while configuring MCC/IP.
- Corrective Action
(None).
- Syslog Message
Configuration error has occured in "%s", while setting up "%s ",with value: "%s", (error string='%s', error code=%d).
- Parameters
objectOper (STRING): Operation being executed.
objectType (STRING): Type of Object - IP address/ Netmask/ Interface / Bootarg
objectValue (STRING): Value of IP address/ Netmask/ Interface / Bootarg
errorString (STRING): The error string
errNum (INT): The internal error code
rlib.mccip.config.missing
- Severity
NOTICE
- Description
This event is generated if any of the environment data relating to the configuration of an MCC/IP DR port is missing on boot.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
objectOper (STRING): Interface being configured.
