ONTAP EMS reference
gpo.job events
gpo.job.mainUpdateFailed
Severity
ERROR
This message occurs when the GPO Main Update job run fails.
Corrective Action
Address the specific reason for the issue, and then run the job again by running the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
Syslog Message
GPO Main Update job (%s) run failed for Vserver %s, reason: %s.
jobid (STRING): GPO job ID.
vserver (STRING): Vserver name.
reason (STRING): Reason for the failure.
gpo.job.mainUpdateSuccess
Severity
INFORMATIONAL
This message occurs when the GPO Main Update job run succeeds.
Corrective Action
(None).
Syslog Message
Successfully completed a GPO Main Update job (%s) run for Vserver %s.
gpo.job.outOfMemory
Severity
ERROR
This event occurs when the system has not enough memory to perform the GPO (Group Policy Object) job.
Corrective Action
Ensure there is enough memory available to perform the GPO job.
Syslog Message
GPO job %s failure: Out of memory.
jobid (STRING): The GPO job ID.
gpo.job.securityApplyFailed
Severity
ERROR
This message occurs when the GPO Security Apply job run fails.
Corrective Action
Address the specific reason for the issue, and then run the job again by entering the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
Syslog Message
GPO Security Apply job (%s) run failed for Vserver %s, reason: %s.
gpo.job.securityApplySuccess
Severity
INFORMATIONAL
This message occurs when the GPO Security Apply job run succeeds.
Corrective Action
(None).
Syslog Message
Successfully completed a GPO Security Apply job (%s) run for Vserver %s.
