gpo.job events
Creating your file...
gpo.job.mainUpdateFailed
- Severity
ERROR
- Description
This message occurs when the GPO Main Update job run fails.
- Corrective Action
Address the specific reason for the issue, and then run the job again by running the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
- Syslog Message
GPO Main Update job (%s) run failed for Vserver %s, reason: %s.
- Parameters
jobid (STRING): GPO job ID.
vserver (STRING): Vserver name.
reason (STRING): Reason for the failure.
gpo.job.mainUpdateSuccess
- Severity
INFORMATIONAL
- Description
This message occurs when the GPO Main Update job run succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully completed a GPO Main Update job (%s) run for Vserver %s.
- Parameters
gpo.job.outOfMemory
- Severity
ERROR
- Description
This event occurs when the system has not enough memory to perform the GPO (Group Policy Object) job.
- Corrective Action
Ensure there is enough memory available to perform the GPO job.
- Syslog Message
GPO job %s failure: Out of memory.
- Parameters
jobid (STRING): The GPO job ID.
gpo.job.securityApplyFailed
- Severity
ERROR
- Description
This message occurs when the GPO Security Apply job run fails.
- Corrective Action
Address the specific reason for the issue, and then run the job again by entering the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
- Syslog Message
GPO Security Apply job (%s) run failed for Vserver %s, reason: %s.
- Parameters
gpo.job.securityApplySuccess
- Severity
INFORMATIONAL
- Description
This message occurs when the GPO Security Apply job run succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully completed a GPO Security Apply job (%s) run for Vserver %s.
- Parameters
