ONTAP EMS reference
gpo.job events
gpo.job.mainUpdateFailed
Severity
ERROR
This message occurs when the Group Policy Object (GPO) Main Update job run fails. Consequently, the policies won't be applied to the CIFS server, requiring a rerun of the update job.
Corrective Action
Make sure Group Policy Object is enabled by running the "vserver cifs group-policy show -vserver <vserver-name>" command, CIFS admin state is up by running the "vserver cifs show -vserver <vserver-name>" and there are no connectivity issues with Active Directory by running "vserver cifs check -vserver <vserver-name>" command, and then run the job again by running the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
Syslog Message
GPO Main Update job (%s) run failed for Vserver %s, reason: %s.
jobid (STRING): GPO job ID.
vserver (STRING): Vserver name.
reason (STRING): Reason for the failure.
gpo.job.mainUpdateSuccess
Severity
INFORMATIONAL
This message occurs when the GPO Main Update job run succeeds.
Corrective Action
(None).
Syslog Message
Successfully completed a GPO Main Update job (%s) run for Vserver %s.
gpo.job.outOfMemory
Severity
ERROR
This event occurs when the system has not enough memory to perform the GPO (Group Policy Object) job.
Corrective Action
Ensure there is enough memory available to perform the GPO job.
Syslog Message
GPO job %s failure: Out of memory.
jobid (STRING): The GPO job ID.
gpo.job.securityApplyFailed
Severity
ERROR
This message occurs when the Group Policy Object (GPO) Security Apply job run fails. Consequently, the security policies are not applied to the CIFS server, requiring a rerun of the apply job.
Corrective Action
Make sure we are able to check the CIFS configuration by running the "vserver cifs show -vserver <vserver-name>" command and the "vserver cifs check -vserver <vserver-name>" command. Run the job again using the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
Syslog Message
GPO Security Apply job (%s) run failed for Vserver %s, reason: %s.
vserver (STRING): Storage virtual machine (SVM) name.
gpo.job.securityApplySuccess
Severity
INFORMATIONAL
This message occurs when the GPO Security Apply job run succeeds.
Corrective Action
(None).
Syslog Message
Successfully completed a GPO Security Apply job (%s) run for Vserver %s.
