gpo.job events
gpo.job EMS events occur when ONTAP encounters issues associated with Group Policy Object (GPO) job execution.
gpo.job.mainUpdateFailed
- Severity
ERROR
- Description
This message occurs when the Group Policy Object (GPO) Main Update job run fails. Consequently, the policies won't be applied to the CIFS server, requiring a rerun of the update job.
- Corrective Action
Make sure Group Policy Object is enabled by running the "vserver cifs group-policy show -vserver <vserver-name>" command, CIFS admin state is up by running the "vserver cifs show -vserver <vserver-name>" and there are no connectivity issues with Active Directory by running "vserver cifs check -vserver <vserver-name>" command, and then run the job again by running the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
- Syslog Message
GPO Main Update job (%s) run failed for Vserver %s, reason: %s.
- Parameters
jobid (STRING): GPO job ID.
vserver (STRING): Vserver name.
reason (STRING): Reason for the failure.
gpo.job.mainUpdateSuccess
- Severity
INFORMATIONAL
- Description
This message occurs when the GPO Main Update job run succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully completed a GPO Main Update job (%s) run for Vserver %s.
- Parameters
gpo.job.outOfMemory
- Severity
ERROR
- Description
This event occurs when the system has not enough memory to perform the GPO (Group Policy Object) job.
- Corrective Action
Ensure there is enough memory available to perform the GPO job.
- Syslog Message
GPO job %s failure: Out of memory.
- Parameters
jobid (STRING): The GPO job ID.
gpo.job.securityApplyFailed
- Severity
ERROR
- Description
This message occurs when the Group Policy Object (GPO) Security Apply job run fails. Consequently, the security policies are not applied to the CIFS server, requiring a rerun of the apply job.
- Corrective Action
Make sure we are able to check the CIFS configuration by running the "vserver cifs show -vserver <vserver-name>" command and the "vserver cifs check -vserver <vserver-name>" command. Run the job again using the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
- Syslog Message
GPO Security Apply job (%s) run failed for Vserver %s, reason: %s.
- Parameters
vserver (STRING): Storage virtual machine (SVM) name.
gpo.job.securityApplySuccess
- Severity
INFORMATIONAL
- Description
This message occurs when the GPO Security Apply job run succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully completed a GPO Security Apply job (%s) run for Vserver %s.
- Parameters
