netinet6.nbr events
netinet6.nbr EMS events occur when ONTAP encounters issues associated with IPv6 Neighbor Discovery operations.
netinet6.nbr.bad.addr
- Severity
ERROR
- Description
This message occurs when ONTAP receives unexpected Neighbor Discovery (ND) packets. The packets could come from various sources, but usually they come from a source IP address. The EMS message shows the information from the packet. If something specific is wrong, another EMS message with more information will display with this EMS message.
- Corrective Action
ONTAP received an invalid Neighbor Discovery (ND) packet. If the condition persists, check your network infrastructure, such as switches, routers, or other connected equipment.
- Syslog Message
nd6_ns_input: src=%s, dst=%s, tgt=%s.
- Parameters
srcIpAddress (STRING): Source IPv6 address.
dstIpAddress (STRING): Destination IPv6 address.
tgtIpAddress (STRING): Target IPv6 address.
netinet6.nbr.bad.tgtAddr
- Severity
INFORMATIONAL
- Description
This message occurs when the target address packet is found to be multicast.
- Corrective Action
(None).
- Syslog Message
nd6_ns_input: Bad NS target (multicast).
- Parameters
(None).
netinet6.nbr.badDstAddr.pkt1
- Severity
INFORMATIONAL
- Description
This message occurs when the destination address packet is bad due to a wrong destination IP6 address.
- Corrective Action
(None).
- Syslog Message
nd6_ns_input: Bad DAD packet (wrong ip6 dst).
- Parameters
(None).
netinet6.nbr.badDstAddr.pkt2
- Severity
INFORMATIONAL
- Description
This message occurs when the destination address packet is bad due to link-layer address option.
- Corrective Action
(None).
- Syslog Message
nd6_ns_input: Bad DAD packet (link-layer address option).
- Parameters
(None).
netinet6.nbr.dad.complete
- Severity
ALERT
- Description
This message occurs when Duplicate address Detection (DAD) for the specified interface address is completed, and duplicate address is found.
- Corrective Action
(None).
- Syslog Message
%s: DAD complete for %s - duplicate found.
- Parameters
ifAddress (STRING): Interface address.
ip6address (STRING): Printable that is a loggable representation of the IP address.
netinet6.nbr.dad.ignrNS
- Severity
INFORMATIONAL
- Description
This message occurs when Duplicate address Detection (DAD) ignores Neighbor Solicitation (NS) packet for the specified interface address.
- Corrective Action
(None).
- Syslog Message
nd6_dad_ns_input: Ignoring DAD NS packet for address %s(%s).
- Parameters
targetAddress (STRING): Printable that is loggable representation of target IPv6 address.
netinet6.nbr.dad.memAlcFail
- Severity
ALERT
- Description
This message occurs when Duplicated Address Detection (DAD) is started and memory allocated fails for the specified interface address.
- Corrective Action
(None).
- Syslog Message
nd6_dad_start: Memory allocation failed for %s(%s).
- Parameters
ip6address (STRING): Printable that is a loggable representation of an IP6 address.
netinet6.nbr.dad.timeout
- Severity
NOTICE
- Description
This message occurs during Duplicated Address Detection (DAD), when number of tries or count to transmit DAD packet exceeds the predefined maximum number of tries.
- Corrective Action
(None).
- Syslog Message
%s: could not run DAD, driver or link problem?
- Parameters
netinet6.nbr.dadtmr.duplcAdr
- Severity
NOTICE
- Description
This message occurs when Duplicated Address Detection (DAD) timer is called, and the parameter passed to it, is a duplicated interface address.
- Corrective Action
(None).
- Syslog Message
nd6_dad_timer: Called with duplicated address %s(%s).
- Parameters
netinet6.nbr.dadTmr.nTntvAdr
- Severity
NOTICE
- Description
This message occurs when Duplicated Address Detection (DAD) Timer is called with non tentative interface address.
- Corrective Action
(None).
- Syslog Message
nd6_dad_timer: Called with non-tentative address %s(%s).
- Parameters
netinet6.nbr.dadtmr.nullPrm
- Deprecated
Deprecated as of Data ONTAP 9.8 since this EMS is no longer needed.
- Severity
NOTICE
- Description
This message occurs when Duplicated Address Detection (DAD) timer is called and the interface address passed to it is NULL.
- Corrective Action
(None).
- Syslog Message
nd6_dad_timer: Called with null parameter.
- Parameters
(None).
netinet6.nbr.duplcte.taddr
- Severity
ALERT
- Description
This message occurs when there is a duplicate target IP6 address.
- Corrective Action
(None).
- Syslog Message
nd6_na_input: Duplicate IP6 address %s.
- Parameters
targetAddress (STRING): Printable that is a loggable representation of target IP6 address.
netinet6.nbr.duplcteSrc.addr
- Severity
INFORMATIONAL
- Description
This message occurs when there is duplicate source IP6 address.
- Corrective Action
(None).
- Syslog Message
nd6_ns_input: Duplicate IP6 address %s.
- Parameters
srcAddress (STRING): Printable that is a loggable representation of source IP6 address.
netinet6.nbr.invld.ndOpt1
- Severity
INFORMATIONAL
- Description
This message occurs because of invalid Neighbor Discovery (ND)option.
- Corrective Action
(None).
- Syslog Message
nd6_ns_input: Invalid ND option; ignored.
- Parameters
(None).
netinet6.nbr.invld.ndOpt2
- Severity
INFORMATIONAL
- Description
This message occurs because of an invalid Neighbour Discovery (ND) option during neighbor advertising input handling.
- Corrective Action
(None).
- Syslog Message
nd6_na_input: Invalid ND option; ignored.
- Parameters
(None).
netinet6.nbr.invld.tgtAddr
- Severity
NOTICE
- Description
This message occurs during Neighbor Advertising (NA)input handling, because of invalid target address.
- Corrective Action
(None).
- Syslog Message
nd6_na_input: Invalid target address %s.
- Parameters
targetAddress (STRING): Target IP6 address.
netinet6.nbr.manl.intvtnReq
- Severity
ERROR
- Description
This message occurs when 'dad_duplicated' is called and manual intervention is required.
- Corrective Action
(None).
- Syslog Message
%s: Manual intervention required.
- Parameters
netinet6.nbr.misMth.lladrln1
- Severity
INFORMATIONAL
- Description
This message occurs when there is a lladdrlen mismatch for the specified IP6 address.
- Corrective Action
(None).
- Syslog Message
nd6_ns_input: lladdrlen mismatch for %s (if %d, NS packet %d).
- Parameters
ip6address (STRING): Printable that is a loggable representation of an IP address.
ifAddrlen (INT): Interface address length.
lladdrlen (INT): Address length.
netinet6.nbr.misMth.lladrln2
- Severity
INFORMATIONAL
- Description
This message occurs during Neighbor Advertising (NA) input handling, when there is a lladdrlen mismatch for the specified IP6 address.
- Corrective Action
(None).
- Syslog Message
nd6_na_input: lladdrlen mismatch for %s (if %d, NA packet %d).
- Parameters
ip6address (STRING): Printable that is a loggable representation of target IP address.
netinet6.nbr.solAdv.mlticstd
- Severity
NOTICE
- Description
This message occurs during Neighbor Advertising(NA) input handling, as solicited advertising is multicast.
- Corrective Action
(None).
- Syslog Message
nd6_na_input: A solicited advertising is multicast.
- Parameters
(None).
