ONTAP EMS reference
netinet6.nbr events
netinet6.nbr EMS events occur when ONTAP encounters issues associated with IPv6 Neighbor Discovery operations.
netinet6.nbr.bad.addr
Severity
ERROR
This message occurs when ONTAP receives unexpected Neighbor Discovery (ND) packets. The packets could come from various sources, but usually they come from a source IP address. The EMS message shows the information from the packet. If something specific is wrong, another EMS message with more information will display with this EMS message.
Corrective Action
ONTAP received an invalid Neighbor Discovery (ND) packet. If the condition persists, check your network infrastructure, such as switches, routers, or other connected equipment.
Syslog Message
nd6_ns_input: src=%s, dst=%s, tgt=%s.
srcIpAddress (STRING): Source IPv6 address.
dstIpAddress (STRING): Destination IPv6 address.
tgtIpAddress (STRING): Target IPv6 address.
netinet6.nbr.bad.tgtAddr
Severity
INFORMATIONAL
This message occurs when the target address packet is found to be multicast.
Corrective Action
(None).
Syslog Message
nd6_ns_input: Bad NS target (multicast).
(None).
netinet6.nbr.badDstAddr.pkt1
Severity
INFORMATIONAL
This message occurs when the destination address packet is bad due to a wrong destination IP6 address.
Corrective Action
(None).
Syslog Message
nd6_ns_input: Bad DAD packet (wrong ip6 dst).
(None).
netinet6.nbr.badDstAddr.pkt2
Severity
INFORMATIONAL
This message occurs when the destination address packet is bad due to link-layer address option.
Corrective Action
(None).
Syslog Message
nd6_ns_input: Bad DAD packet (link-layer address option).
(None).
netinet6.nbr.dad.complete
Severity
ALERT
This message occurs when Duplicate address Detection (DAD) for the specified interface address is completed, and the duplicate address is found.
Corrective Action
The IP address is already in use by another system on the network. The system that is holding the IP address is identified by MAC address. Please ensure that the IP address you are trying to assign is not already assigned to another system.
Syslog Message
%s: DAD complete for %s - duplicate found. %s is holding the IP address.
ifName (STRING): Interface name.
ip6address (STRING): IPv6 address that is found to be a duplicate.
ipHolderMac (STRING): MAC address of the device holding this IP.
netinet6.nbr.dad.ignrNS
Severity
INFORMATIONAL
This message occurs when Duplicate address Detection (DAD) ignores Neighbor Solicitation (NS) packet for the specified interface address.
Corrective Action
(None).
Syslog Message
nd6_dad_ns_input: Ignoring DAD NS packet for address %s(%s).
targetAddress (STRING): Printable that is loggable representation of target IPv6 address.
ifAddress (STRING): Interface address.
netinet6.nbr.dad.memAlcFail
Severity
ALERT
This message occurs when Duplicated Address Detection (DAD) is started and memory allocated fails for the specified interface address.
Corrective Action
(None).
Syslog Message
nd6_dad_start: Memory allocation failed for %s(%s).
ip6address (STRING): Printable that is a loggable representation of an IP6 address.
netinet6.nbr.dad.timeout
Severity
NOTICE
This message occurs during Duplicated Address Detection (DAD), when number of tries or count to transmit DAD packet exceeds the predefined maximum number of tries.
Corrective Action
(None).
Syslog Message
%s: could not run DAD, driver or link problem?
netinet6.nbr.dadtmr.duplcAdr
Severity
NOTICE
This message occurs when Duplicated Address Detection (DAD) timer is called, and the parameter passed to it, is a duplicated interface address.
Corrective Action
(None).
Syslog Message
nd6_dad_timer: Called with duplicated address %s(%s).
netinet6.nbr.dadTmr.nTntvAdr
Severity
NOTICE
This message occurs when Duplicated Address Detection (DAD) Timer is called with non tentative interface address.
Corrective Action
(None).
Syslog Message
nd6_dad_timer: Called with non-tentative address %s(%s).
netinet6.nbr.dadtmr.nullPrm
Deprecated
Deprecated as of Data ONTAP 9.8 since this EMS is no longer needed.
Severity
NOTICE
This message occurs when Duplicated Address Detection (DAD) timer is called and the interface address passed to it is NULL.
Corrective Action
(None).
Syslog Message
nd6_dad_timer: Called with null parameter.
(None).
netinet6.nbr.duplcte.taddr
Severity
ALERT
This message occurs when there is a duplicate target IP6 address.
Corrective Action
(None).
Syslog Message
nd6_na_input: Duplicate IP6 address %s.
targetAddress (STRING): Printable that is a loggable representation of target IP6 address.
netinet6.nbr.duplcteSrc.addr
Severity
INFORMATIONAL
This message occurs when there is duplicate source IP6 address.
Corrective Action
(None).
Syslog Message
nd6_ns_input: Duplicate IP6 address %s.
srcAddress (STRING): Printable that is a loggable representation of source IP6 address.
netinet6.nbr.invld.ndOpt1
Severity
INFORMATIONAL
This message occurs because of invalid Neighbor Discovery (ND)option.
Corrective Action
(None).
Syslog Message
nd6_ns_input: Invalid ND option; ignored.
(None).
netinet6.nbr.invld.ndOpt2
Severity
INFORMATIONAL
This message occurs because of an invalid Neighbour Discovery (ND) option during neighbor advertising input handling.
Corrective Action
(None).
Syslog Message
nd6_na_input: Invalid ND option; ignored.
(None).
netinet6.nbr.invld.tgtAddr
Severity
NOTICE
This message occurs during Neighbor Advertising (NA)input handling, because of invalid target address.
Corrective Action
(None).
Syslog Message
nd6_na_input: Invalid target address %s.
targetAddress (STRING): Target IP6 address.
netinet6.nbr.manl.intvtnReq
Severity
ERROR
This message occurs when 'dad_duplicated' is called and manual intervention is required.
Corrective Action
(None).
Syslog Message
%s: Manual intervention required.
netinet6.nbr.misMth.lladrln1
Severity
INFORMATIONAL
This message occurs when there is a lladdrlen mismatch for the specified IP6 address.
Corrective Action
(None).
Syslog Message
nd6_ns_input: lladdrlen mismatch for %s (if %d, NS packet %d).
ip6address (STRING): Printable that is a loggable representation of an IP address.
ifAddrlen (INT): Interface address length.
lladdrlen (INT): Address length.
netinet6.nbr.misMth.lladrln2
Severity
INFORMATIONAL
This message occurs during Neighbor Advertising (NA) input handling, when there is a lladdrlen mismatch for the specified IP6 address.
Corrective Action
(None).
Syslog Message
nd6_na_input: lladdrlen mismatch for %s (if %d, NA packet %d).
ip6address (STRING): Printable that is a loggable representation of target IP address.
netinet6.nbr.solAdv.mlticstd
Severity
NOTICE
This message occurs during Neighbor Advertising(NA) input handling, as solicited advertising is multicast.
Corrective Action
(None).
Syslog Message
nd6_na_input: A solicited advertising is multicast.
(None).
