raid.readerr events
raid.readerr.lw.data.ckinfo
- Severity
INFORMATIONAL
 - Description
This message occurs when the system detects an inconsistent RAID write signature, during a RAID error handling operation to log the on-disk RAID checksum information of the data block on the corresponding RAID stripe.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
owner (STRING): Owner of the affected aggregate.
disk_name (STRING): Name of the data disk.
dbn (LONGINT): Disk block number of the block being reported.
disk_pos (INT): Position of this data disk in the corresponding RAID group. The generation count of this data block on the parity bitmap resides at this position.
stripe_id (INTHEX): Stripe ID field of the RAID write signature on the data block.
gen_cnt (INTHEX): Generation count field of the RAID write signature on the data block.
comp_cksum (INTHEX): Computed RAID checksum of the disk block.
sto_vbn (LONGINT): Volume block number stored in the checksum entry.
wafl_cxt0 (INTHEX): Bytes 0-3 of WAFL® context information in the checksum.
wafl_cxt1 (INTHEX): Bytes 4-7 of WAFL context information in the checksum.
wafl_cxt2 (INTHEX): Bytes 8-11 of WAFL context information in the checksum.
wafl_cxt3 (INTHEX): Bytes 12-15 of WAFL context information in the checksum.
wafl_cxt4 (INTHEX): Bytes 16-19 of WAFL context information in the checksum.
wafl_cxt5 (INTHEX): Bytes 20-23 of WAFL context information in the checksum.
wafl_cxt6 (INTHEX): Bytes 24-27 of WAFL context information in the checksum.
wafl_cxt7 (INTHEX): Bytes 28-31 of WAFL context information in the checksum.
disk_serialno (STRING): Serial number of the disk drive.
raid.readerr.lw.dparity.ckinfo
- Severity
INFORMATIONAL
 - Description
This message occurs when the system detects an inconsistent RAID write signature, during a RAID error handling operation to log the on-disk RAID checksum information of the diag parity block on the corresponding RAID stripe.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
disk_name (STRING): Name of the diag parity disk.
stripe_id (INTHEX): Stripe ID field of the RAID write signature on the diag parity block.
gen_cnt1 (INTHEX): Generation count bitmap field of the RAID write signature on the diag parity block, for data blocks 0-15.
gen_cnt2 (INTHEX): Generation count bitmap field of the RAID write signature on the diag parity block, for data blocks 16-27.
raid.readerr.lw.id.inconsist
- Severity
NOTICE
 - Description
This message occurs when the system detects an inconsistent RAID write signature on a RAID stripe, during a RAID error handling operation. Data ONTAP® makes appropriate recovery actions. It automatically fails this device safely if the device exceeds the allowed number of inconsistent RAID write signature errors on the disk.
 - Corrective Action
(None).
 - Syslog Message
Inconsistent RAID write signature detected on RAID group %s%s, stripe #%llu, during RAID error handling operation
 - Parameters
rg (STRING): Name of the RAID group.
stripe (LONGINT): Stripe number.
raid.readerr.lw.id.inconsist.dirty
- Severity
INFORMATIONAL
 - Description
This message occurs when the system detects an inconsistent RAID write signature on a RAID stripe that belongs to a dirty parity region, during a RAID error handling operation.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
raid.readerr.lw.parity.ckinfo
- Severity
INFORMATIONAL
 - Description
This message occurs when the system detects an inconsistent RAID write signature, during a RAID error handling operation to log the on-disk RAID checksum information of the row parity block on the corresponding RAID stripe.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
disk_name (STRING): Name of the row parity disk.
stripe_id (INTHEX): Stripe ID field of the RAID write signature on the row parity block.
gen_cnt1 (INTHEX): Generation count bitmap field of the RAID write signature on the row parity block, for data blocks 0-15.
gen_cnt2 (INTHEX): Generation count bitmap field of the RAID write signature on the row parity block, for data blocks 16-27.
raid.readerr.lw.reconsBadBlk.ckinfo
- Severity
INFORMATIONAL
 - Description
This message occurs when the system encounters a RAID stripe with an inconsistent RAID write signature that might indicate a bad data block somewhere on the stripe. Based on this block's RAID signature, the system suspects this block as containing bad data and reconstructs the the block for a data integrity check. This message logs the RAID checksum information from the reconstructed block.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
comp_cksum (INTHEX): Computed RAID checksum of the reconstructed block.
iteration (INT): Parity consistency of this RAID stripe is restored by performing a data integrity check on one or two stripe blocks at a time in an iteration. This variable prints the current iteration.
raid.readerr.lw.reconsGoodBlk.ckinfo
- Severity
INFORMATIONAL
 - Description
This message occurs when the system encounters a RAID stripe with an inconsistent RAID write signature that might indicate a bad data block somewhere on the stripe. Based on this block's RAID signature, the system identifies this block as containing good data and reconstructs the block to perform a data integrity check on a suspected bad data block in the stripe. This message logs the RAID checksum information from the reconstructed good block.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
raid.readerr.lw.tparity.ckinfo
- Severity
INFORMATIONAL
 - Description
This message occurs when the system detects an inconsistent RAID write signature, during a RAID error handling operation to log the on-disk RAID checksum information of the tparity block on the corresponding RAID stripe.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
disk_name (STRING): Name of the tparity disk.
stripe_id (INTHEX): Stripe ID field of the RAID write signature on the tparity block.
gen_cnt1 (INTHEX): Generation count bitmap field of the RAID write signature on the tparity block, for data blocks 0-15.
gen_cnt2 (INTHEX): Generation count bitmap field of the RAID write signature on the tparity block, for data blocks 16-27.
raid.readerr.recovered.file
- Severity
NOTICE
 - Description
This event is issued when a lost write block has been recovered from parity and other remaining data disks.
 - Corrective Action
(None).
 - Syslog Message
Recovered the bad disk block %llu on %s%s, %s inode number %d, snapid %d, treeid %d, file block %llu level %d.
 - Parameters
blockNum (LONGINT): The disk block number
owner (STRING): String indicating the owner of the affected volume.
disk_info (STRING): Formatted information of the disk
ino_type (STRING): The inode type
fileid (INT): The file identifier
snapid (INT): The snapshot identifier
treeid (INT): The snapshot identifier
fileBlockNum (LONGINT): The block number in the file
level (INT): The level
