wafl.vvol events
wafl.vvol.create.encrypted
- Severity
NOTICE
 - Description
This message occurs when an encrypted flexible volume is created.
 - Corrective Action
(None).
 - Syslog Message
New %s encrypted volume %s is created on aggregate %s.
 - Parameters
key_type (STRING): This Indicates encryption type of this volume is NetApp Aggregate Encryption (NAE) or NetApp Volume Encryption (NVE).
vol (STRING): Volume name.
aggr (STRING): Name of the containing aggregate.
voluuid (STRING): Volume UUID.
keyid (STRING): Encryption Key ID.
buftreeid (INT): Buftreeid.
cp_count (INT): Consistency Point (CP) at which this volume is created.
wafl.vvol.delete.metadata.recrm
- Severity
NOTICE
 - Description
This message occurs when the system cannot remove volume metadata during a volume delete operation after moving it to recycle bin.
 - Corrective Action
(None).
 - Syslog Message
Could not remove volume %s%s%s metadata. Error: %d.
 - Parameters
vol (STRING): Name of the flexible volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier for the volume when the volume name alone is insufficient.
errorCode (INT): Error number.
wafl.vvol.delete.metadata.rename
- Severity
NOTICE
 - Description
This message occurs when the system cannot rename volume metadata during a volume delete operation.
 - Corrective Action
(None).
 - Syslog Message
Could not rename volume %s%s%s metadata. Error: %d.
 - Parameters
wafl.vvol.delete.metadata.rm
- Severity
NOTICE
 - Description
This message occurs when the system cannot remove volume metadata during a volume delete operation. The system will retry removing the metadata during any operation that brings the containing aggregate online(for example, takeover).
 - Corrective Action
(None).
 - Syslog Message
Cannot remove volume %s%s%s metadata. Error: %s(%d).
 - Parameters
reason (STRING): Reason for the failure.
wafl.vvol.delete.recovered
- Severity
INFORMATIONAL
 - Description
This event occurs when a flexible volume that was queued for delete is recovered.
 - Corrective Action
(None).
 - Syslog Message
Volume %s%s%s%s recovered.
 - Parameters
owner (STRING): String indicating the owner of the affected volume.
wafl.vvol.destroyed
- Severity
NOTICE
 - Description
This message occurs when a flexible volume is destroyed.
 - Corrective Action
(None).
 - Syslog Message
Volume %s%s%s%s destroyed.
 - Parameters
vol_btid (INT): Internal buftree identifier for the volume.
wafl.vvol.encrypted.offline
- Severity
INFORMATIONAL
 - Description
This message occurs when an encrypted virtual volume is taken offline.
 - Corrective Action
(None).
 - Syslog Message
Volume '%s%s%s' is encrypted and was taken offline.
 - Parameters
name (STRING): Volume name.
volident (STRING): Unique identifier of the volume when the volume name by itself is insufficient.
wafl.vvol.excessive.contsize
- Severity
ERROR
 - Description
This message occurs when a flexible volume container that exceeds the maximum size supported on the running platform is detected. This event can be encountered after a headswap to a platform supporting a lower maximum capacity.
 - Corrective Action
Back up the dataset in the volume as soon as possible and take the volume offline. Alternatively, consider a system or hardware upgrade to a platform that supports a higher maximum capacity.
 - Syslog Message
Volume '%s' exceeded the maximum container capacity supported on this platform (container blkcnt=%llu, maxlimit=%llu). Back up the dataset and take the volume offline as soon as possible.
 - Parameters
vol (STRING): The volume name
blkcount (LONGINT): The total blocks capacity of the volume container
maxblkcount (LONGINT): The maximum container capacity supported on the platform
wafl.vvol.excessive.volsize
- Severity
ERROR
 - Description
This message occurs when a flexible volume that exceeds the maximum size supported on the running platform is detected. This event can be encountered after a headswap to a platform supporting a lower maximum capacity.
 - Corrective Action
If possible, shrink the flexible volume using the 'vol size' command. If not, back up the dataset in the volume as soon as possible and take the volume offline. Alternatively, consider a system or hardware upgrade to a platform that supports a higher maximum capacity.
 - Syslog Message
Volume '%s' exceeded the maximum volume size supported on this platform (nominal blkcnt=%llu, maxlimit=%llu). Shrink the volume or back up the dataset and take the volume offline as soon as possible.
 - Parameters
blkcount (LONGINT): Total block count of the volume.
maxblkcount (LONGINT): Maximum block count supported on the platform.
wafl.vvol.invalid.DSID
- Severity
ERROR
 - Description
This message occurs when ONTAP® finds a volume with an invalid data set identifier (DSID). This might have occurred as a result of disk corruption.
 - Corrective Action
Contact NetApp technical support to have a new DSID assigned to the volume as soon as possible.
 - Syslog Message
Volume '%s%s%s' has an invalid DSID (0x%x).
 - Parameters
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
dsid (LONGINT): Data set identifier.
wafl.vvol.move.encrypted
- Severity
NOTICE
 - Description
This message occurs when an encrypted destination volume is created as part of volume move operation.
 - Corrective Action
(None).
 - Syslog Message
%s encrypted volume %s%s%s is created on aggregate %s as part of a volume move operation.
 - Parameters
wafl.vvol.offline
- Severity
INFORMATIONAL
 - Description
This message indicates when a virtual volume is taken offline.
 - Corrective Action
(None).
 - Syslog Message
Volume '%s%s%s' has been set temporarily offline
 - Parameters
instuuid (STRING): Volume Instance UUID
wafl.vvol.offline.err
- Severity
NOTICE
 - Description
This event is issued if the system fail to set the raid label of the virtual volume when it's taken offline.
 - Corrective Action
(None).
 - Syslog Message
Error persistently transitioning volume %s%s%s from 'restricted' to 'offline', unable to update descriptor, error %d
 - Parameters
name (STRING): The volume name
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
error (INT): The error code
wafl.vvol.offline.persist
- Severity
INFORMATIONAL
 - Description
This message occurs when a flexible volume that was marked temporarily offline as part of the volume migration process is now marked persistently offline.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
wafl.vvol.online
- Severity
INFORMATIONAL
 - Description
This event occurs when the state of flexible volume moves to the online state.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
vol (STRING): The name of the flexible volume
instuuid (STRING): Volume instance UUID
wafl.vvol.ownVserver.changed
- Severity
INFORMATIONAL
 - Description
This message occurs when either a cluster repair tool changes the owning vserver of the volume, or when the volume is transitioned from being a node volume to a cluster volume or vice versa.
 - Corrective Action
(None).
 - Syslog Message
Volume '%s%s' owning vserver / name changed to '%s%s%s'.
 - Parameters
oldname (STRING): Original name of the volume.
oldownerIdent (STRING): Original vserver identifier.
newname (STRING): New name of the volume.
newownerIdent (STRING): New vserver identifier.
wafl.vvol.renamed
- Severity
INFORMATIONAL
 - Description
This message occurs when the administrator renames a flexible volume.
 - Corrective Action
(None).
 - Syslog Message
Volume '%s%s' renamed to '%s%s%s'.
 - Parameters
oldname (STRING): Original volume name.
volident1 (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
newname (STRING): New volume name.
volident2 (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
wafl.vvol.restrict
- Severity
INFORMATIONAL
 - Description
This event is issued to indicate a flexible volume has been restricted
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
wafl.vvol.vvlabel.error
- Severity
ERROR
 - Description
This message occurs when the verification of the vvlabel fails on a flexible volume. This event provides all the information available in the vvlabel so that it can be used later, for recovery.
 - Corrective Action
Contact NetApp technical support.
 - Syslog Message
Cannot determine volume label information (%s). (Flexible volume with UUID '%s', unique ID '%d' on aggregate '%s' with raidtree ID '%s')
 - Parameters
err (STRING): Error string.
voluuid (STRING): UUID of the flexible volume as identified by the metadir.
id_in_aggr (INTHEX): Unique ID within the containing aggregate.
aggr_name (STRING): Containing aggregate name.
aggr_rtid (STRING): RAID tree ID of the aggregate.
version (INTHEX): vvlabel version.
mirror_flags (INTHEX): Mirror type flags.
vol_flags (INTHEX): Flags for the volume.
fsid (INTHEX): File system identifier for the volume.
clone_parent (INTHEX): 'id_in_aggr' value of the clone's parent volume.
base_snapid (INTHEX): Clone base Snapshot(tm) copy ID.
vvuuid (STRING): UUID of the flexible volume as identified by the vvlabel.
vvol_type (INTHEX): Flexible volume's type.
dsid (LONGINTHEX): Volume data set identifier.
msid (LONGINTHEX): Volume master data set identifier.
owneruuid (STRING): UUID of the owning Vserver.
volname (STRINGARRAY): Volume name in raw hexadecimal format.
wafl.vvol.xfer.nospacedestErr
- Severity
ERROR
 - Description
This event indicates that the transfer to a destination flexible volume has failed because the aggregate than contains this volume is out of space.
 - Corrective Action
Increase space available in the aggregate by either adding disks or freeing space by deleting aggregate snapshots, shrinking flexible volumes or moving flexible volumes to another aggregate. Ensure that there is sufficient space available in the aggregate (using the df -A command) to accommodate the flexible volumes it contains. The vol size command may be used to obtain flexible volume sizes and also to grow or shrink them.
 - Syslog Message
Transfer to volume '%s%s%s' failed because the containing aggregate, '%s', is out of space.
 - Parameters
aggr (STRING): The aggregate name
