The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mw.iron events
Creating your file...
Your file is ready
mw.iron.mount.idlog.purge
- Severity
INFORMATIONAL
- Description
This message is used to notify idlog purge at mount after 7 consecutive unsuccessful iron runs.
- Corrective Action
(None).
- Syslog Message
Volume[%s] : Wafliron mount performance may be significantly impacted, because idlog purge is triggered after[%d] unsuccessful iron runs.
- Parameters
vol (STRING): Name of the volume.
generation (INT): Iron generation number.
