The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
maxcid.limit events
Creating your file...
Your file is ready
maxCID.limit.exceeded
- Severity
ALERT
- Description
This message occurs when system exceeds the maximum number of open network data connections on the node.
- Corrective Action
Balance the network load across all nodes within the cluster in order to avoid disruptions in service. Contact NetApp technical support.
- Syslog Message
Number of active data connections is %d and system limit is %d.
- Parameters
activeCID (INT): Number of open data connections on the node.
maxCID (INT): Maximum allowed limit of data connections per node.
