maxcid.limit events
maxCID.limit.exceeded
- Severity
ALERT
- Description
This message occurs when system exceeds the maximum number of open network data connections on the node.
- Corrective Action
Balance the network load across all nodes within the cluster in order to avoid disruptions in service. Contact NetApp technical support.
- Syslog Message
Number of active data connections is %d and system limit is %d.
- Parameters
activeCID (INT): Number of open data connections on the node.
maxCID (INT): Maximum allowed limit of data connections per node.
