ONTAP EMS reference
maxcid.limit events
maxcid.limit EMS events occur when system exceeds the maximum number of open network data connections on the node.
maxCID.limit.exceeded
Severity
ALERT
This message occurs when system exceeds the maximum number of open network data connections on the node.
Corrective Action
Balance the network load across all nodes within the cluster in order to avoid disruptions in service. Contact NetApp technical support.
Syslog Message
Number of active data connections is %d and system limit is %d.
activeCID (INT): Number of open data connections on the node.
maxCID (INT): Maximum allowed limit of data connections per node.
