The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
acp.downrev events
Creating your file...
Your file is ready
acp.downrev.acpp
- Severity
ERROR
- Description
This message occurs when the Alternate Control Path Administrator cannot successfully download up-to-date firmware to an Alternate Control Path Processor (ACPP) or when the most up-to-date firmware image is not present in the /etc/acpp_fw/ directory.
- Corrective Action
Verify that the latest ACPP firmware is available in the firmware directory. If the firmware update continually fails to download up-to-date firmware, then replace the ACPP I/O module.
- Syslog Message
ACPP module %s (%s) has downrev firmware.
- Parameters
inband_id (STRING): In-band ID of the ACPP module.
ip (STRING): IP address of the ACPP module.
