The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
disk.eos events
Creating your file...
Your file is ready
disk.EOS.OS.error
- Severity
ALERT
- Description
This message occurs when a disk is detected that is not supported in this version of Data ONTAP® or later
- Corrective Action
Remove the disk and replace it with a disk that is supported.
- Syslog Message
%s support ended in version of %s. Current version is %s.
- Parameters
disk_information (STRING): Disk information.
EOS_OS_version (STRING): Latest version of Data ONTAP supported by the disk.
cur_OS_version (STRING): Current version of Data ONTAP.
