ONTAP EMS reference
disk.eos events
disk.eos EMS events occur when a disk is detected that is not supported in this version of Data ONTAP® or later.
disk.EOS.OS.error
Severity
ALERT
This message occurs when a disk is detected that is not supported in this version of Data ONTAP® or later
Corrective Action
Remove the disk and replace it with a disk that is supported.
Syslog Message
%s support ended in version of %s. Current version is %s.
disk_information (STRING): Disk information.
EOS_OS_version (STRING): Latest version of Data ONTAP supported by the disk.
cur_OS_version (STRING): Current version of Data ONTAP.
