ONTAP EMS reference
mlm.arraylun events
mlm.arraylun EMS events occur when Data ONTAP® cannot install one or more discovered array LUNs since the disk device count is at full capacity.
mlm.arrayLUN.limit.exceeded
Severity
ALERT
This message occurs when Data ONTAP® cannot install one or more discovered array LUNs since the disk device count is at full capacity.
Corrective Action
If possible, remove an existing disk or array LUN so that array LUN installation can proceed. If the failure persists, contact NetApp technical support.
Syslog Message
Unable to install one or more array LUNs [ vendor '%s' product '%s' ] discovered on initiator port %s, array target port WWNN: %s, WWPN: %s. The disk device limit (%d) has been reached.
vendor (STRING): Vendor ID of the storage array.
product (STRING): Product ID of the storage array.
adapter (STRING): Name of the initiator port discovering the array LUN(s).
wwnn (STRING): World Wide Node Name of the array target port exporting the array LUN(s).
wwpn (STRING): World Wide Port Name of the array target port exporting the array LUN(s).
limit (INT): Disk device maximum count.
