mlm.arraylun events
Creating your file...
mlm.arrayLUN.limit.exceeded
- Severity
ALERT
- Description
This message occurs when Data ONTAP® cannot install one or more discovered array LUNs since the disk device count is at full capacity.
- Corrective Action
If possible, remove an existing disk or array LUN so that array LUN installation can proceed. If the failure persists, contact NetApp technical support.
- Syslog Message
Unable to install one or more array LUNs [ vendor '%s' product '%s' ] discovered on initiator port %s, array target port WWNN: %s, WWPN: %s. The disk device limit (%d) has been reached.
- Parameters
vendor (STRING): Vendor ID of the storage array.
product (STRING): Product ID of the storage array.
adapter (STRING): Name of the initiator port discovering the array LUN(s).
wwnn (STRING): World Wide Node Name of the array target port exporting the array LUN(s).
wwpn (STRING): World Wide Port Name of the array target port exporting the array LUN(s).
limit (INT): Disk device maximum count.
